All services and warning lights come on....
Ok, if I drive hard for quite a long time, like over 45min spirited driving, all of a sudden car gets in safe mode with every engine and service like turning on, abs, 4wd, engine service and so on......it stay like this for about 2 minutes, than back to normal......what should I look at? Tune too aggressive? Low battery voltage?
Also make sure your tune is not pushing more than about 350-400tq MAX b/c that ALL the trans can take with stock clutches in it. also if you are going to beat on the car you must do the following with the SST
no WOPs until the trans temp is around 120
no Launches until the trans temp is around 170
Make sure the car is in sport of S-sport if you are going to drive like hell (i always drive my car in S-Sport manual)
If you have a COBB APv3 make sure your tuner open source tuned the SST for the added power.
Check out Kozmic motorsports for the following
Bigger SST oil Pan
SST Cooler system
Upgraded clutches
alsong2002
Jul 13, 2017 11:40 AM
Evasive EVO
EvoX 'For Sale' Services
13
Jan 20, 2017 03:21 PM
Evasive EVO
Evo 'For Sale' Services
12
Mar 3, 2011 05:15 PM
