Exhaust to turbo bolt keeps coming loose
Hey all,
I wanted to see if anyone else has had any experience regarding the manifold bolt that keeps coming loose.
Out of the 4 bolts, only the bottom left corner one keeps coming loose.
I know bolts can loosen from heavy/hard driving but mine seems to come loose when under normal driving.
If the other 3 are tight, will it cause any leaks with that 1 bolt loosened up?
I am trying a locking washer to see if that helps.
Replace the gasket, and the bolts. Torque to 45ftlbs. And use the OEM convex spring washers. FP sells them. You use 2 per bolt like this
==()==, shouldn't have issues anymore.
Derek888
Oct 10, 2005 06:30 AM
adotwhite
Apr 7, 2005 10:54 PM
