Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to install wideband O2 sensor bung
Old Aug 5, 2008 | 10:27 AM
MechEE's Avatar
I'm surprised that the X's stock O2 sensor isn't a wideband. I'm used to seeing stock widebands for the last 7 years or so. Can anybody confirm the make and model of the stock O2 sensor? Thanks.
Old Aug 7, 2008 | 06:17 AM
skynet_'s Avatar
I think that only really few cars have stock wideband sensors..
Old Nov 10, 2008 | 01:15 PM
itzcharlez's Avatar
would it work if i stick welded the o2 bung? i know its archaic but thats all i have..
Old Jan 18, 2009 | 08:47 AM
honda-guy's Avatar
back from the dead.
my friend is installing a wideband in his Evo X.
where did you tap the power wire to in the car?
Old Feb 9, 2010 | 11:58 PM
oscargarza88's Avatar
i got my o2 bung welded in today but it looks different from urs. Mine does not go in the exhaust at all like yours does. Do you think that will be an issue?
further explanation, the tip of the bung/sensor is at the smae level as the wall of the exhaust, not inserted.
thanks
Old Mar 23, 2010 | 03:20 PM
yorT's Avatar
So would the red dot I put in this pic be a better location for the bung? To get it closer to 3 o'clock?
Attached Thumbnails How to install wideband O2 sensor bung-3bunglocation.jpg
Old Mar 25, 2010 | 07:28 PM
yorT's Avatar
Originally Posted by evostang
Pics of the sensor wire routing.
Where at in the cabin does the wiring come in? And did you have to remove some of the snaps holding the fender up?
Old Mar 27, 2010 | 10:48 PM
ik78's Avatar
I would also like to know where you ran the wire into the cabin please.
Old Mar 27, 2010 | 11:33 PM
stokEd's Avatar
Follow the wire coming off the front O2 sensor (grey wire in the top of the pic above.) It passes through a grommet underneath the passenger side floor. You'll need to pop a couple plastic panels off and pull back the carpet to access it.
Old Mar 27, 2010 | 11:35 PM
stokEd's Avatar
Pics here: https://www.evolutionm.net/forums/ev...-etc-pics.html
Old Mar 28, 2010 | 07:10 PM
yorT's Avatar
Thanks but was able to find an unused grommet in the passenger fender. Works great.
Old Mar 29, 2010 | 05:58 AM
reggiesd's Avatar
this is where i ran mine as well...except i used the driver side since that's where my old prosport boost gauge wire ran to the engine bay (when i installed the boost gauge: https://www.evolutionm.net/forums/ev...lean-hell.html i had a lot of extra lines left with the o2 sensor wire which i just tucked in under the steering wheel column.
Old Mar 31, 2010 | 02:12 PM
gungravevn's Avatar
Subscribed
Old May 1, 2010 | 07:42 PM
wrxnevox's Avatar
nice diy
Old Jun 6, 2010 | 08:18 AM
rrkpitt15's Avatar
What about buying a test pipe with 2 o2 bungs and installing the wideband there??
Quick Reply: How to install wideband O2 sensor bung
