Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to remove rear seats?
Old Jan 2, 2009 | 09:31 PM
MR Dan's Avatar
Is there a link somewhere for the rear seat removal? search results showed nothing.
Old Jan 3, 2009 | 04:18 AM
jdmjunkiee's Avatar
it's quite easy. i believe it's two to three clips that hold the bottom seats down. pull up and away on each side and it should come right up. then you will see a couple bolts that need to be unbolted *socket and ratchet, not sure what the size is*. Once that is off. you will lift up the backseat, by doing this it will clear the brackets/hooks that are holding the rear seats in place. if i miss anything my bad, and you will see it for yourself that it's quite simple. gl
Old Feb 18, 2009 | 02:55 PM
Q15H's Avatar
The bolt heads for the seat back mounts, three of them, is a 14mm hex. You will want to also remove two of the 3-point harness mounts, which use a 17mm hex head bolts. the center and left side. Remove the head rests from the back seat section before removing the rear seat. Be sure to note where/how the belts and buckle ends come through the lower seat section before removing it. They do not go through the slots in the rear seats.
You will need a helper to re-install the rear seat section as there are three hooks to push the seat onto as you push it down. Then have the same helper assist with pushing the seat lower rearwards enough to engage the front clips. Don't forget to pull the seat belt buckles through as you install the lower.
With two people it'll take ten minutes to R&R both rear seats.
Old Feb 18, 2009 | 05:57 PM
lowkey's Avatar
Registered User
I removed mine without removing the seatbelts or headrests. I just used zipties to tie the belts to the grabhandles to get them out of the way.
BTW, with the rear backrest removed, you have access to the damper nuts.
Old Feb 18, 2009 | 06:33 PM
MR Dan's Avatar
damn these rear seats are MUCH heavier than the Evo 8-9 rear seats
Old May 15, 2009 | 02:39 PM
evox119's Avatar
Rear Seat pics
Hey guys I got some pics that might help out with removing the seats. Pretty much just follow what the other posts say to do. Should take about 10 min for removal and reinstall
Old May 15, 2009 | 02:54 PM
DrasticK's Avatar
Step 1: Lift up to pop the lower seat portion out of the clips
Step 2: Lift up and out to remove the lower portion
Step 3: Unbolt the upper seat
Step 4: Lift up and pull out to remove upper seat
if i remember correctly thats all there was to it.
Old May 15, 2009 | 06:03 PM
DrasticK's Avatar
Originally Posted by friski_nardin
no need to remove the seatbelts and no need to have a second help I just did the same thing 2 days ago without any help and took me less than 15 mins, good luck.
Yea, putting it back in is extremely useful to have a second person, but other than that everything is straight forward. Pull on this, tug on that this way, unbolt that, and it's all out.
Old May 19, 2009 | 04:18 PM
WolvieDC's Avatar
just wanted to add there is some good info and rear seat diagrams on another how to Evo x post...
look up the tread on How to install OEM back up camera he has a step where the seats are removed and the Service manual diagram of the rear seat attachment points
Old Jun 11, 2009 | 03:53 AM
Scottyb's Avatar
Registered User
SUPER EASY 3 bolts! less weight more sound. MORE RAW EVO
Old Jun 13, 2009 | 05:34 PM
bradze's Avatar
i assume once the seat is out the seatbelts(shoulder part) are easy to get to, right?
Old Mar 13, 2010 | 02:13 PM
s281evoxfq400's Avatar
i did mine this morning and it was super easy
Old Sep 1, 2010 | 02:04 AM
smokee04's Avatar
is it really worth pulling the back seat out i was interested in doing it
Old Sep 1, 2010 | 08:18 PM
bradze's Avatar
this is for evo X, it says you have an 8. are you thinking of just removing it for weight? not at all worth it unless you pull everything are a serious track junkie
Old Sep 2, 2010 | 01:55 AM
smokee04's Avatar
ya i have an 8 and ya i was asking about weight reduction
Quick Reply: How to remove rear seats?
