How you change your HID light bulbs without removing the bumper?
Is there a way to remove the light bulbs in a SSS packaged HID Evo X without having to remove the bumper. I heard some people did it without removing the bumper. I got as far as removing the plastic cap enclosing the bulb but I have no clue what is next to remove whatever because I can't see inside of the housing. Does anyone know the next step after removing the plastic cap?
From looking at the Evo8/9 forums with HID projectors, they had a step where they need to turn a socket counter-clockwise to remove ballast, and then there is some sort of spring clip that needs to be moved aside before the bulb can be taken off. I'm wondering if we have that same spring clip.
I did the same as Guru on the driver side but on the passenger side I just moved the AC High preasure line i believe a lil bit which is held on by 2 clips.. and then u can squeeze your hand on the back of the cover and remove the bulb.
Evoryder
90
Jun 22, 2017 03:26 AM
