Help Forge Unos and Prosport Boost gauge
Okay so i had the fun of trying to install a Forge uno MBC on th X. Took me about 3 hrs not cuase it was hard but becuase i could not get the hoses off the nipples and had to cut most of them.
Now i went from the turbo nipple and the wastegate nipple to the MBC.
Another thing is i got rid of the stock tubing that was orginally going from the turbo and wastgate which boht went to a T and followed back to the boost soleiod thats on the top far right of the x.
LIke i said i couldnt get some of the tubbing so i had to cut. them only becuase when i was trying to pull the tubs off one of the boost soleioids i got the tubbing off but the nipple came with it as well. This only happen with one this is when i started to cut cause got scared.
Now it it okay if the right bottom boost soleiod is missing its nipple i mean with the MBC now it isnt even needed or used anymore. so i figured it did even matter am i right?
Second i have no idea how to hook up the Prosport gauge the hows i saw arent that great . I T in the boost gauge into the wasgate so is that right i was gnna go of the BOV linebut i figure since i had the wasgate tubbing and niple off i jsut go off that?
Help anyone?
Help anyone?
its very hard to understand what your typing, but you can T anywhere from the intake manifold->BOV line. Anywere from that vacumm line is a good accurate place to get boost signal from.
Alright have everything hooked up but IM ONLY BOOSTING MAX 10 PSI NO MATTER HOW MUCH I TURN THE BOOST UP!!
Any idea what could be happening? i checked all connections and they are snugged and zipped tied. i also cap the two stock boost soleniod openings that are left open and threw electircal tap around it also.
any idea
any idea
svt_lightning01
Mar 31, 2011 01:08 PM
mscorei
20
Mar 5, 2008 06:45 PM
