Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
AMS EVO X O2 Eliminator 3.0" Downpipe Installation
Old May 2, 2009, 08:51 AM
  #106
Bighec's Avatar
Is there supposed to be a gasket where the o2 pipe meets the turbo?
Old May 2, 2009, 09:01 AM
  #107
rogue's Avatar
Yes sir. Use the stock one.
Old May 2, 2009, 09:09 AM
  #108
Bighec's Avatar
Thanks for the quick answer. Just got my piece yesterday, and was going to install it tomorrow. Didn't want to wait any longer. Thanks.
Old May 2, 2009, 03:17 PM
  #109
newMRevoNyne's Avatar
+1
The stock gasket is a nice heavy duty piece that can def be re-used. When I had it all disassembled I was surprised at the quality of the stock gasket, very impressive!
Old May 2, 2009, 03:20 PM
  #110
Also, some insight into removing the one stud left in the stock O2 housing cause that can be re-used as well. Go to any local autoparts store (Autozone, O'Reily, Napa etc.) And get thier loaner stud remover tool set. Make sure they have the metric kit (10mm as I remember) to use on the stud or else it will chew up the threads bad. You can actually bring in the stock O2 housing and the new AMS piece and just swap the stud in the store and that way you dont have to rent the set and then bring it back.
Old May 2, 2009, 03:27 PM
  #111
Talon_66's Avatar
or just buy a 1.5" Grade 8 hardened nut and bolt.
Old May 2, 2009, 03:48 PM
  #112
jirro22's Avatar
very nice
Old May 2, 2009, 04:10 PM
  #113
Registered User
lowkey's Avatar
My AMS piece came with a new stud
Old May 2, 2009, 04:26 PM
  #114
Mine did too, hahah, I just swaped it in, but the tool helps for putting the new stud in as well. or do what Talon 66 said.
Old May 2, 2009, 08:16 PM
  #115
Bighec's Avatar
Tomorrow is the big day! I hope everything goes well. I bought some heavy duty penetrating oil for the job. I would start tonight, but my work lamp took a dump.
Old May 3, 2009, 11:30 AM
  #116
Bighec's Avatar
12
Old May 3, 2009, 11:31 AM
  #117
Bighec's Avatar
Finished the job. 3.5 hrs. No broken bolts thank god! Wasn't as bad as I thought it would be.
Old May 3, 2009, 12:15 PM
  #118
Evo-IX-MOMO248's Avatar
how does it feel? any significant gains you feel?
Old May 3, 2009, 12:28 PM
  #119
Bighec's Avatar
It seems to pull a little harder. Sounds great. I put on the test pipe, and the o2 eliminator.
Old May 3, 2009, 01:25 PM
  #120
missionstatemen's Avatar
did you get it off if so how did you do it ?
Originally Posted by Talon_66
OMG! I HATE this install, or should I say uninstall!
I have 4 of the 5 bolts on the passenger side off.
I cant get the o2 housing heat shield off to reach the last ****ing bolt!
Quick Reply: AMS EVO X O2 Eliminator 3.0" Downpipe Installation
