Oil temperature and pressure sensors for Greddy Informeter - oil sandwich?
Hello guys,
I want to purchase the Greddy Informeter Touch that can read some parameters from OBD and display all in a nice way:
I also want to add some additional sensors (using the specific adapter that allows to read them directly in the Informeter), in particular oil temperature and pressure sensors.
Greddy itself provides an "oil filter sandwich"
but the question is: with the oil filter sandwich, the oil filter will be too low on vehicle? If so, do you know another way to easily place theese 2 sensors on EVO X?
Then, this oil filter adapter from Greddy is described as "universal": someone has already installed it on EVO X without problems?
Thank you for your answers and suggestions, and sorry for my English but it's not my language and I'm in a hurry now...
Bye
Stefano
Bye
Stefano
for the X, the sandwich is fine. There is plenty of clearance and the filter is covered by your undertray. Theres a good 2 inches of clearance so this sandwich should fit without problems since it only drops the filter down by 1 - 1 1/2 inches at most.
dtfrost5
May 13, 2016 07:33 PM
plan:b
Nov 16, 2012 08:19 AM
adapter, evo, filter, greddy, informeter, ix, oil, parameters, pressure, sandwich, sensor, sensors, temp, temperature, touch
