Quick Install: AMS Shifter Base Bushing
Im not good with giving instructions, so here is a combination of pictures and words. Overall the install was pretty easy. Took me about 20-30 minutes start to finish.
Here are the toolsI used (Wrench, extension, 12mm socket, smaller wrench: for pushing out the metal ring)
Step 1.) Remove plastic covers to expose the shifter base.
Here is a photo of the shifter base. Circled are the bolts that needs to be removed. There are four of them.
Step 2.) Remove the four bolts. I used a 12 mm socket to remove them.
Step 3.) Once removed. Push down on the metal washer in the middle of the stock rubber bushing. (There is not enough room to show what I did, so i removed it from the base, and showing you the process)
I used the other end of my wrench to push it out. Feel free to use anything that will make it easy for you.
This is how they looked like once removed (Rubber bushing and metal washer)
Stock and AMS Base Bushing Side by side
Step 4.) Place the AMS Base bushing under the Shifter Base
Step 5.) Use the four bolts again and tighten everything down.
Step 6.) Place everything back! your Done!
this will probably be my first mod, the factory shifter is so long and the throws are insane. How hard is it to actually get all the stuff out of the way in order to install a short shifter?
FS[West]: ETS Downpipe / ETS HFC / Depo UICP
CmakEVOX
Oct 18, 2015 05:49 AM
AWDani
For Sale - Cars For Sale
Apr 29, 2014 08:39 AM
CmakEVOX
For Sale - Wheels / Tires
Mar 12, 2014 05:48 AM
