Interior Rattle
#35
Both the Instrument cluster and glove box rattles.
I fixed the glove box rattle by placing some adhesive rubber tabs on the contact points in the glove box. This made the glove box door fit tight when closed.
The instrument cluster rattles while driving and goes away when I put hand pressure on top of it. I have no idea how I'm going to fix this since I don't see any screws on it so that I can remove the cluster. If I could remove the cluster, I would put some kind of felt tape along all edges.
#39
EvoM Community Team
Are you talking about the A-pillar? My B-Pillar rattles like crazy sometimes. It's in the seatbelt adjustment. On the A-pillar, I'd use some buytl on the connection to make it tight. My right door panel was rattling, so I put buytl in each one of the butt connectors. Noise is now gone.
#41
#42
i got like almost a loose screw sound from inside the dash near the glove box... it sounds like someone's blowing a whistle from the next room. I'm not sure if it's the glove box or not cus I hold it tight sometimes to check and it stop, but sometimes it doesn't.... it does it when at about 2k rpm. car's brand new.... gotta track this down. It bugs big time.... I just blast my stereo everywhere I go so I don't hear that squeek.
#43
The glovebox rattle has started happening bad now that the weather is getting into the 50's...so loud that my open exhaust isn't loud enough to cover it up...I'm going to try this glovebox fix and hope it helps
#45
