Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Has anyone made a custom heat shield for Cobb SF Intake?
Old Jul 17, 2009 | 01:09 PM
JerseyEvox's Avatar
Has anyone made a custom heat shield for Cobb SF Intake? i heard rumors that when the a/c is on that the car does not run smoothly cause of the added heat going to the cobb sf intake.
i also was looking at the ams intake heat shield, looks like it might fit with the cobb
Old Jul 18, 2009 | 12:56 AM
Clipse3GT's Avatar
Here is my how to...
https://www.evolutionm.net/forums/ev...hield-sri.html
Old Jul 18, 2009 | 03:07 AM
Porkskins's Avatar
I would gladly send you templates. You will need 2 Office Despot aluminum clipboards, vice, rotary tool, and a large coffee can or knee.
https://www.evolutionm.net/forums/ev...sf-intake.html
heres hoping I dont double post...
Old Jul 18, 2009 | 07:53 AM
JerseyEvox's Avatar
you're awesome +99999
Old Jul 22, 2009 | 10:30 PM
alex3dworld's Avatar
Summit Racing.com sell a generic Air cone filter heat shield. really cheap, $15-$20. if you are short in time go for it.
Ams also sells a heat shield for their Evo X Ram Intake, but be careful, it's not exactly compatible with Cobb. Cob Intake is shorter meaning some Air still will afect the intake.
Old Jul 22, 2009 | 11:32 PM
Clipse3GT's Avatar
I been using my heatshield for about 2 months now. I have no idle issues with A/C on or off.
Old Jul 25, 2009 | 12:59 AM
mertdinc's Avatar
that set up looks nice however seriously flawed
air intake needs to be straight, there is no need for a sharp bend .
cut a hole in the base for the pipe and extend the whole back side of the guide to the maf sensor
that way all the air flows direct to the intake without turbulence
or not..
my two cents..
Old Jul 25, 2009 | 02:02 AM
Porkskins's Avatar
or not..
my two cents..
I am guessing you are replying to my post. Its a heat shield for blocking hot air from the AC fan(per the thread), not any kind of cold air system.
For the purpose it was built for, it works. With only the SF intake my engine would stumble at idle regularly when it was over 90f and the AC fan kicked on. With the heat shield I only get a very rare stumble that lasts less than a second, and only when its hotter than around 98f outside. I would have loved to made a better setup, but I worked with what I had to make a temporary fix. It turned out to work so well that I painted it and kept it.
If you come up with a better solution please let us know and send me some templates
Old Jul 25, 2009 | 03:19 PM
ImEv0's Avatar
looks great...
Old Nov 26, 2009 | 03:51 AM
gnorrell's Avatar
I use the AMS heatshield. You have to bend it a little bit and its not perfect but it works.
europaul
Oct 11, 2016 03:35 PM
chrisfri13
Cobb AccessPORT
Dec 23, 2014 11:24 AM
ak47m203
Mar 10, 2014 11:02 AM
anglaenan7
Sep 23, 2013 01:48 PM
Porkskins
23
Sep 20, 2010 10:30 PM
