problem on installing the Hotchkis fron sway bar
hi,
i went to a shop today to install the front sway bar, and they said i have to set on the stiff one because if i set it on the soft one, it will touch something, so does anyone have this problem?
thanks
Nick
thanks
Nick
Could you take a picture of it?
Here are the instructions from the Hotchkis website: http://www.hotchkis.net/_uploaded_fi...416782file.pdf
At the bottom of p.10 there are pics of the swaybar that show how they mate with the endlinks. Have a look and see that your bar is situated in the same manner.
mm...im not sure why....but it should not upside downed... they let me saw it, and when it is on soft setting, it's very very close to touch the axle, and they try to free play around the bracket to put it back to clear the axle, but the sway bar will touch the sub frame or something...
but well they do it, the front wheels is not lifted... and i think they were try to lift it up, but still had the problem...(that is what i saw only)
so i don't know...
and for the picture, what part do you guys want me to take?
thanks alot
Nick
so i don't know...
thanks alot
Nick
Something doesn't sound right. I have the Hotchkis sway bars installed on my X, front and rear and there both on the medium setting and we had no problems with anything touching.
Hmm, I'm not that familiar with the Hotchkis bar, in particular, but it looks just like it shows in the install pictures from them. ??
Keep in mind that when the suspension strokes, all of those components will move upward (the halfshaft will not remain in one place while the endlink moves upwards, etc.).
Good luck!
Good luck!
Good luck!
Good luck!
GL
Just wanna chime in this thread for any future hotchkiss front sway peeps. I just installed my bar and i have about 1/8 inch clearance between the front swaybar and the front axle. I'm kind of afraid it may touch in extreme roll cases as the pivot point for the driveshaft is inboard of the control arm, meaning the control arm will rise faster than the axle. I havn't decided if i'm going to take a dremel to the swaybar yet. I'll decide if things don't improve after i remove preload and examine clearance again.
DarkSyde294
Lancer How Tos / Installations
Apr 24, 2016 12:25 PM
turbotalawd
Jul 16, 2014 10:17 PM
CanuckLancer
27
Nov 5, 2013 03:50 AM
tsbevo
19
May 24, 2010 07:14 AM
love67
46
Mar 18, 2010 11:05 PM
