Engine oil draining from oil cooler
Hi guys, last weekend I changed engine oil on my X (it was really dark after only 2500 miles) and I could fill only with 4.5 liters of new oil. Old oil was drained correctly (car was well warmed up and I let it drain for over 10 minutes), but I think that there's always a big amount of old oil that stays in the oil cooler. In fact, new oil became immediately darker, mixing with the old oil.
So, next time I want to drain all the old oil also from the cooler: someone knows if there's a screw on/near the cooler that makes this operation easier or do I have to remove directly the oil pipes coming to the cooler?
Thanks in advance for your suggestions.
Stefano
Stefano
Freebs
Mitsubishi TC-SST Discussion
Sep 4, 2015 10:08 AM
