DIY Injectors EVOX
DIY Injectors EVOX
Im no mechanic, in fact I had problems with lego's when I was a child... Doing this will cause serious damage to your engine and possibly you blowing the F#$* up.. Do this on your own discretion, I'm simply posting this as a reference (pictures) of what I did... ( hopefully it will help some of you) In addition, feel free to let me know if I screwed something on up aswell
I planned on running E85 on my X for a couple of months now, after completing all the supporting mod/parts, I finally decided to pull the trigger last night and apply everything that I have read and learned through this forum. (big thanks to all who contributed)..
This however, will specifically be about installing my Dw 800cc injectors (1000cc's are next) since not too many reference were ever post about installing Inj. about injectors. I myself had a problem searching for our specific car which is the X..
Tools used...
Long nose Plier
Wrenches
10mm
8/9 mm
12 (i forgot if this is the right size for the 2 bolts on the fuel rail)
extension
Regular Pliers
RAGS
GLOVES
Here are my goodies
Blaqops kit
255walbro (thanks Ryan Gates)
Dw Injectors (AMS)
I disconnected my battery -/+
My engine bay (dirty)
I started with the 2 bolts that held up the metal bracket by the driver side.
DC the adapter that goes on the Stock Inj. (4)
DC the tubing on top of the engine
DC bolts that held up the Fuel Pipe
DC the two main bolts that held the fuel rail. There are two black spacers between the Fuel Rail that hold keep the Inj spaced.. after dc the one of the 2 bolts becareful not to drop them under bec. it will be a pita if you do... undo one bolt and move on to the next...
Here's how the spacer look like...
After, dc the fuel rail bolts.. the rail could be move now, fuel pipe was freed up too... when you get enough space in between... unplug the stock injectors by gently pulling them one at a time. There are metal fastners that goes inward towards the car... Do not drop these unless you want extra noises and clanking in you engine bay... GENTLY pry them off and securing them from falling off..
When you pull the INJ they have the O rings attached top side of the Fuel Rail... some will come off with the Inj. some won't so becareful not to drop these aswell.. 3 out of 4 stayed on the fuel rail for me, I pulled them out with a Long nose Plier.
Also, at this point fuel will spew out... grab rags to clean up mess.. (especially with the first injector that you pull) Depressurize the lines was something that I missed... so search how to do that... if you do attempt to continue... fuel will flow out not much but good enough amount to stink.. also, If I may add.. open up windows or doors for ventilation, I got drozy and doopey...
Stock Inj vs. DW's
pic's of the stock INJ
Installing the DW's is pretty simple.. Don't forget to apply liberal amount of Lube on the 0 Rings top/bottom if you didn't get lube then apply with motor oil instead. Here's a picture of my Dw's installed.. when you have all four.. don't forget the black spacers.. don't drop them either! secure all 4 inj. and then work on one side to the next...
I didn't reuse the metal fasteners that went in the stock injectors.. I didn't think that I would need them since the DW's are pretty secure and fat up top.. After securing the fuel rail, I just bolted the rest of the parts that I took apart...
I might have forget some steps but if you can call me on it.. I might add later on... Oh by the way I did this during a freakin snow storm lastnight..
Mahalo!!!!!
Tools used...
Long nose Plier
Wrenches
10mm
8/9 mm
extension
Regular Pliers
RAGS
GLOVES
Here are my goodies
Blaqops kit
Dw Injectors (AMS)
Stock Inj vs. DW's
Mahalo!!!!!
^My blaqops double pumper came with pretty decent install instructions. The single is way easier if that is what you are doing, so the instructions that come with it should be adequate. Otherwise there is an install for the DIY 255 kit on evoxforums that you could use for reference as well.
Unfortunately, I don't have the steps on how to- w/ the blaqops but like murlo says it comes with instructions and many posts from other members gave sufficient information regarding the install... when I got my blaqops kit it didn't come with instructions.. But I have been researching prior of lastnight.. and knew where to find answers.. I caught a snag, with the inline filter that the blaqops came with.. and was really stump by that.. In retrospect, I would have taken an hour to install the kit knowing what I learned... but yea it really straightforward...
^^^ yes that damn thing.... I was so gentle with it too, since don't want to break nothing.. then after staring at it for like an hour I finally got it to come loose SNAP... and RED quick connect line to the fuel rail... also took me another hour to decide to cut or should I bend the metal rail where the red quick connect lines up..... then LIGHTBULB came on... spliced the oem quick connect to get it out.. and spliced the inline filter (JEGS) .....connected and bingo... done! ahahah sorry, just had to let that out of my chest... Lol!!!!!!!!!!
I am hoping for 410whp or so, we shall see Stock clutch has to hold together!
Good write up. In regards to depressurizing the system I think you just need to pull the fuel pump fuse, or unplug the fuel pump and start the car. It will quickly drain the fuel system/pressure.
naku ganyan din ako, i guess we are just not used to wearing them while working on cars. here i try to use them too but end up just taking them off yun nga lang gaspang na ng skin mo afterwards .
