AVC-R installation please help! Throttle and Speed signal?
Hi
I'm installing AVC-R on an Evo X
I'm confused on which ECU wiring to tap to when it comes to Throttle Signal Wire and Vehicle Speed Signal.
According to...
http://roadraceengineering.com/evox/...-ecuwiring.htm
which pin should I tap for those two?
I have a feeling Throttle Signal wire would be pin 10 - Throttle position sensor (main)
but the (sub) and ground is confusing me
and nothing indicates Speed signal
Please help!
Thanks
Henry
According to...
Please help!
Thanks
Henry
I'm PRETTY sure I used #74 for the TPS. Use the Acc pedal, otherwise the TPS will show different fluctutations as the factory throttle body is also the idle control valve. As for speed you need to grab it off the harness behind the radio . It's not hard to get to. I made a picture and posted it on here. Try searching under AVIC. I had to extend my harness and run it through the grommet by the left footrest.
cant seem to find the pic for the speed wire for EVO X - can help?
much thks
cky3396
124
Jul 6, 2012 04:02 PM
leonard_shelby
23
Mar 31, 2008 04:57 PM
alainusmc
24
Sep 18, 2005 09:06 AM
