catch can for less than 30 dollars!
Hi, I had these installed on my evo 8 and now my 10. This idea was by hokiruu so big thanks to him.
https://www.evolutionm.net/forums/ev...bout-20-a.html
materials needed:
can clamp
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
support bracket
and of course, the catch can
http://www.pegasusautoracing.com/pro...asp?RecID=4703
a few bolts and nuts i had laying around....
finished set-up:
passenger side mounting location:
drivers side mounting location:
top view:
for the lines: i used 3/8 ID fuel hose and some worm clamps to secure. have fun!
materials needed:
can clamp
support bracket
finished set-up:
top view:
Mine worked out well, mirrors your outside of the fact that I ran the IM hose on the right side of the dip stick. thanks again for posting this.
I do wonder at Boost if a bit of air doesnt push past the fittings where the hose is crimped down.?
I dont know, I would assume our catch can conditions would mirror that of the IM so under boost, 25 or so psi, I just wonder if that will push past the fittings where the larger hose is crimped down over the tiny fitting.?
hmmm...some just run a breather set-up with their valves and just put filters although they need to be tuned with it if im right. i think it is just a blow by and not a full pressure compared to the pipings,etc...
hmm could be,
I know on the valve cover side there is just blow by, so putting a filter here would not be a problem, however, if you have any opening on the intake system your going to have issues i think, while I dont believe we have an opening I was thinking that perhaps under pressure (max boos) air might be forced around our fittings and past our hose clamps and out into the atmosphere, while this doesnt create a real issue with MAP or MAF its more of a partail boost leak. I suppose the amount of lost pressure if any would likely be so marginal its no issue..
I used the same locations but I'm thinking the valve cover side run is too long. I'm moving the can so that it attaches to one of the boost control solenoid bolts instead...much shorter run.
People do it that way as well. I'm sure it would work. I was just making sure that the can and line from the cover to the cam is really low to aid with moving the oil and the line from can to intake is high to prevent oil seepage.
Am I mistaken when I see that you cannot open the can? You need to put something inside the can like copper sell pad so it will catch the oil.
Also, when you are running a can on the PCV system, you should put some sort of check valve in front of teh can coming from the manifold so the can dosent get "boosted" which will cause the oil inside the can to blow everywhere.
I found a can that has the oild catcher already installed and also comes with a check valve and drian port. its simular to the Perrin cans in design. Ive been running it on my car for a while now, seems to work great. And prolongs the life of your PCV valve.
http://cgi.ebay.com/ebaymotors/EVO-X...Q5fCarQ5fParts
its 15 more bucks and it works.
