AMI pillar gauge install
Day 2 of Xmas gift installs (Day 1 was AGP FMIC) was the AMI pillar 2 gauge pod with PLX Devices Boost and A/F gauges.
AMI makes are really nice product - fit and finish were perfect. This set-up gives you a real OEM quality. The AMI install instructions found on the website were clear and easy to follow. The pillar popped right off and the new one popped right in.
While there are cheaper alternatives, no one matches up the OEM quality of fit and finish like AMI.
We choose PLX Devices gauges because we had used them before and like them a lot. PLX gauges come in two parts the display (1/2 -3/4 deep) and a brain box which is great when space is limited. The brain boxes were installed right of the fuse panel.
A/F - We added a bung to our test pipe and ran the wiring via the grommet on the passengers foot well.
Boost - we ran the line following this thread which is very helpful if you need to get wires from the drivers side into the engine bay. Worthy of a bookmark.
https://www.evolutionm.net/forums/evo-x-h...ml#post8804089
We are very happy with the results and had a great father and son day with this mod.
This is the dual low mounts, apparently the low mounts are the most popular and the gauges are not in your face. Both gauges are perfectly visible. The only thing I wish was that the PLX boost gauge had a max boost read button.
I can appreciate for a track car, you probably want the gauges in a direct line of site but for show or DD this is the way to go in my opinion.
mrwickd123
Evo X How Tos / Installations
11
Nov 2, 2016 10:19 PM
evolv
10
Jun 18, 2010 01:43 PM
superscout03
12
Mar 2, 2008 02:23 AM
