Power source:AEM UEGO & Digital Boost
hey guys, Im about to install these two gauges at the same time. I was reading some threads that showed people tapping power from the Cig/*** fuse below the driver side and using the bolt near by for ground. Can I use that to power 2 gauges or do I have to tap another source?
any help is appreciated.
ok cool, where did you mount your gauges? Im still undicided if i want them on my steering columb or under the climate controls...
I ran power to my aem gauges using an add-a-circuit mini fuseholder. It basically lets you add a fuse in parallel with another fuse of your choice in the fuse panel. I like it cuz you dont have to tap into the factory wiring, its just plug and play, and its easy to reverse. I just ran the ground to one of the metal brackets under the dash that was relatively close to the gauge. works great.
i was going to use the cig/*** fuse to power my boost gauge, and utilizing the info from a how to thread, using the thicker red wire under the passenger side door trim for power for the UEGO. Is there any i should be aware of if i do it this way?
Assassin
10
Apr 6, 2023 12:14 PM
EvoIXPilot
Nov 30, 2012 06:46 PM
blakroyal
Feb 2, 2012 10:44 AM
mchristian
Feb 20, 2010 12:27 AM
