Window Rattle
Window Rattle
Before I posted this I searched and could not find a thread pertaining to this particular problem. I saw the glove box and windshield rattle threads but not a window rattle.
My passenger door window is rattling. I finally found where it was coming from today and can push against a certain spot on the door to stop the rattle, also cracking my window stops the rattle.
Is there a fix I can do? Or will the dealer actually take care of this? I rolled off the lot brand new on December 31st 2011
Car info: 2011 Evo X MR
I had the same problem and I took my car into Mitsubishi because it was pissing me off. They took the door panel off a told me that a bolt becomes loose from vibration and they loctite it and the rattling went away. He said it was a common problem.
Mine does some stupid noise also on the passenger side, but only when it's rolled up. It drives me crazy. So what I do is pull over and reach over and just open and close the door and it actually helps a little. I should try the dealership.
I started noticing mine a few days ago and its getting worse and worse, makes me wonder if it is a bolt(s), gonna take the door panels off soon. I'll take pics if I can find what does this and post them.
