EVO X GSR Maintenance Questions
Hello everyone! The time has come for me to get the EVO nice and cleaned up for my next HDPE event! I've been to Willow 3 (Four if you count twice the normal runs on the same day) times, and in that time have demolished the stock tires, and destroyed the brake pads.
Also, since the car is only at 4.5k miles, the engine got some serious "breaking in" and needs an oil change.
Oh yeah, and the brake lines need to be flushed, because... I don't like vapor lock.
So, my questions are...
1. What are good High Performance pads which fit STOCK evo X GSR Brembos? (Front and Back please)
2. I would like to get the brakes flushed. Can any mechanic do it? Or is there a specific place that I should be going to get them done? (Because, you know, they're Brembo Brakes) Not somewhere like BrakeMasters where some 18 year old haphazardly flushes the brakes and then I get brake failure on the track.
I've got the oil-change and tires already figured out, so I'm good for those. And, sorry for the beginner questions, it's my first time maintaining a "high-performance" vehicle.
https://www.evolutionm.net/forums/ve...rake-pads.html
Flushing the brakes is easy, consider doing it yourself while you're changing the brake pads.
http://www.joe250.com/cars/evo8/brak...ebleeding.html
This write-up is done on an Evo VIII, but the procedure is the exact same for the IX and X.
Thanks for the info! Do those Girodisc pads fit stock evo gsr brakes? You said you changed your brakes in the post you linked, so I want to make sure they still fit stock brakes.
Also, how are they in terms of performance for track?
Thanks
you have tracked your car 3x and haven't changed the oil?
flush the brake fluid for sure, go with a good dot4 fluid. motul rbf600 or ate typ 200 (since ate super blue is no longer available) are both considered good track fluids.
But I will seriously look into the Orange series pads if the report for my current pads comes back bad. And I will definitely flush the lines.
I'll purchase the good race braking fluids and have mechanic replace my current fluids with it.
@Kracka, thanks for the great tip on pads! They seem more affordable and they seem to have great ratings!
i would avoid repeating that mistake again.
also, depending on how much you are actually going to track the car, consider buying a separate set of track pads (and possibly a 2nd set of wheels and tires too).
... but it sounds like you aren't going to do the work yourself so that makes it annoying to take it somewhere every time you want to swap pads.
Smike
626
Dec 15, 2021 09:03 AM
Smike
63
Apr 29, 2019 07:27 AM
FS[SouthEast]: 2004 Evo 8 | HPDE Track Car| $15k
Creatre
For Sale - Cars For Sale
Oct 4, 2015 05:13 PM
boomn29
188
Aug 8, 2012 08:25 AM
