The Ultimate Aggressive Wheel Thread... Evo X Style
#482
^so it is really the tires in terms of clearance issue, not so much on the rims itself and I wouldn't be able to tell without the tires mounted on.
You're right, actual tire size varies from different brands and model. Usually the more aggressive track tires are more bulgy at the sidewalls than street tires. I will probably look into Advan Sport 265-35-19.
Too bad the CE28Ns jumps from 9.5 to 10.5, but the latter does give more lip
That is the same brand of tire I am using but 285/30/19... The CE28Ns are A+ I can't see how a car could look bad with a set of those.
Keep in mind the few hints we gave you and you should be safe and soon sporting one if not the must aggressive tire/wheel setup here.
#483
No spacers required. All you have to do is roll all the fenders.
Since you found a set of 19x10.5 +22 CE28N's, I would suggest what Carrito said, which is pulling, rolling, studs, spacers, and cambering all at the same time to make a 275's or even 285's fit.
It's all up to you bro.
#484
Thanks guys! I picked up some great info in the past 30mins on this thread. Gotta get my head straight now and decide which route to take.
The wheels should be at the shop next week and I will go test it out. Looking forward to be a part of this thread with the new setup
#485
Post pics and lots of it! LOL...
