The Ultimate Aggressive Wheel Thread... Evo X Style
Old Jan 28, 2009 | 05:56 AM
  #661
aftershock141's Avatar
Originally Posted by PlayinWithFire
please for the love of god stop quoting pictures!
lulz.
Old Jan 30, 2009 | 05:15 PM
  #662
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Okay guys, I was thinking about going with some 19x9.5 with a +23 offset with Volk GTS wheels..........I know fender rolling may need to be done but what type wheel spacer will I need. Gunmetal on Octane Blue
Old Feb 1, 2009 | 08:04 AM
  #663
joe_r's Avatar
From what I've been reading, 19x9.5 et20-23 is perfect for the widest with no roll. You won't need a spacer. But what tire width you run on it will determine if you rub without a roll. A 275 will more likely roll, than a 265 or 255. Also the guys running 275s on 10.5s with subt 20 ets also are running negative camber thats fairly aggressive for the street.
Here is my current favorite wheel size comparison.
Wheel size comparison
I preloaded it with a 275/30/19 on a 19x9.5 et23.
"Package will stick out 30 mm (1.2'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset. "
backspace clearance: 3 mm (0.1'') shorter
"100% clear (leaves even more room than OEM)"
Old Feb 1, 2009 | 09:45 AM
  #664
^^You are the man!!!! Now the only issue I have to deal with is pot-holes.................
Old Feb 2, 2009 | 10:01 PM
  #665
ArchieBabes's Avatar
Wheels: Volk CE28N Formula Limited
Wheel Size: 19X10.5 +22 Offset
Tire Size: Falken 452 275/35/19
Modification:
1. Rear Fenders Rolled and Flared.
2. Front Fenders Rolled.
3. Suspension adjustsments to fit.
I'm going with wider tires when it's time to repalce it.
285/30/19
Old Feb 2, 2009 | 10:39 PM
  #666
jdmsneakerhead's Avatar
^so sexy!!!
Old Feb 3, 2009 | 12:03 AM
  #667
joe_r's Avatar
Modification:
285/30/19
holy crap that looks hot. the whole car. love those mirrors! what are they?
275/35s are huge in diameter! (okay .5" isn't huge in diameter, but its huge in circumference :-D ), the 285/30s will probably fit fine since they aren't as tall (perfect diameter). maybe a wee bit more camber. either way, I can't wait to see it!
Does 10.5 +22 have any clearance issues on the inside?
Old Feb 3, 2009 | 12:09 AM
  #668
joowick's Avatar
JUN mirrors
Old Feb 3, 2009 | 12:16 AM
  #669
joe_r's Avatar
i've got this burning question, and this is the best thread I can think of, even tho it's kind off topic:
does tire stretch affect overall diameter?
Old Feb 3, 2009 | 01:33 AM
  #670
EvolvedVIII's Avatar
Yes, but not overtly.
Old Feb 3, 2009 | 01:55 AM
  #671
4drboost's Avatar
CE28's look hawt
Old Feb 3, 2009 | 07:32 AM
  #672
Fishstix's Avatar
How wide should a tire be to house a 9.5' wide rim with absolutely no tire stretch?
Old Feb 3, 2009 | 07:38 AM
  #673
ForcedFedRS's Avatar
Probably a 265 or 275, depends on the tire manufacturer as their sizes vary.
Old Feb 3, 2009 | 08:09 AM
  #674
evoxjersey's Avatar
quick question would this fit on the evo x 18X7.5 45+ silver nakayama with nangkang esII tires
Old Feb 3, 2009 | 08:41 AM
  #675
de_pellerin_luc's Avatar
Thanks for that Joe!
Wish I'd known about this sooner!
Quick Reply: The Ultimate Aggressive Wheel Thread... Evo X Style
