Gauges installed in center console
Hi,
Not really a full on 'How to' posting so i decided to post here instead of the DIY folder...
This is where i wanted to install 2 60mm Defi meters and the controller. Pretty tight!
After many measurements, cutting/fitting.....Final template shows it can be done...
Mounting plate made from 3mm hardboard
Completed! Oh ya...buddy of mine converted the LED's on the controller from white to amber to match
Nightshot
The cockpit
Nightshot
The cockpit
Thanks. The important ones (boost/water temp/oil temp) are easily seen on the dash. The two in the console are oil press/ext temp. I can still see them but more like wait for the warning beep if anything goes wrong
LOL.... I would think the total opposite... oil press/egt are the most important ones.... the others will beep if the water/oil temp get to high.. and you will feel if the boost drops....
Just my .02.
Looks nice
-Chris
