Damaged aero kit! help
So I ran over some unknown object, and cracked the front piece of my aero kit (2008 evox). It def will need to be replaced and painted. Can you guys help me with all the options I have for replacing this? Can you order only the front piece of the aero kit from mits? I also have considered an aftermarket front lip -- does anyone have or heard of the seibon oem replacement?
http://www.advancespeedshop.com/seib...oe-p-8599.html
Any suggestions would be appreciated. Thanks!
I will post some pics up tomorrow.
The two aftermarket choices I have found so far are the Seibon OEM carbon fiber replacement, and the blacktop aero lip. It sounds like the Seibon is actually fiberglass wrapped in CF, which sucks -- it would prob snap easier than the stock piece.
Is anyone aware if you can order the front lip only from mits? If not i'll call on Monday.
Same thing happened to me, It's cracked thru where the driver side piece attaches near the cutout for the intercooler.
I believe Russell from MitsubishiParts.net in Washington quoted me like $550 shipped for the aero kit lip painted.
I'm going to take it to a body shop and see if it can be fixed/painted for cheaper before i bite the bullet and go that route.
I also have a damaged front lip. The previous owner used bondo to fix it but it has started to chip and looks horrible. I plan on replacing with cf but in the meantime, what is under the aero kit lip? Is it just a normal air dam bumper with that lip? I was thinking about removing it for now untill i replace it. If anyone knows, give me a shout back. Thanks guys!
I think this would be a good opportunity try something aftermarket!
The OEM lip looks good, but I think there are better aftermarket ones out on the market. Just my 0.2 cents.
EvoGeneration
EvoX 'For Sale' Exterior Styling
79
Jan 15, 2015 04:22 PM
GenomeTuning
168
Jul 2, 2014 09:31 AM
BrakeOptions
15
Apr 6, 2011 08:54 AM
Evasive EVO
34
Aug 4, 2009 12:06 PM
