Engine dress-up
They're platinum cured silicone hoses (that’s the type of silicone I guess).
They're all 4mm, except for a small section that's a 6mm (10” maybe). If you're planning on changing all the vacuum hoses make sure you have a boost controller or some sort of boost measuring mechanism since you will be removing the factory boost restrictor pill that’s on one of the lines.
CarFanatic
25
Mar 6, 2006 04:40 PM
rt turbo
Mar 3, 2004 10:47 AM
Evo11V
Jan 11, 2004 09:42 AM
