Buschur Racing Crossflow Exhaust - Pics & a question
i finally got around to taking pictures and a video clip, i will upload and post tonight. Probably start a seperate thread and write a little review, i will link to that from here
its being installed by a muffler shop as we speak, i just told them to figure it out, i think it just looks massive cause its in my house, i be the flange does bolt up to the cat.
i'll do a full review of the exhaust in a new thread after i drive around with it on for a couple days.
what's a good alternative for this catback?
whats the difference between this and the magnaflow exhaust thats alot cheaper? So far the only thing i can figure out is that the flange that bolts to the cat is not 3" and bottlenecks a little on the exhaust from magnaflow. Cheap and easy fix though, and even if you didn't want to fix it, the impact on performance would be minimal if you are running stock downpipe and cat.
Why is the crossflow 300$ more?
http://www.cvrmotorsports.com/store/...roduct_id=4075
We are talking about smooth flow here though... not adding up inner diameters. That's like saying if you merged a ingle 3 inch into 7 0.5 inch pipes you would have better flow because there are 7 of them and you have a higher overall diameter number. Of course I am exaggerating here but I am trying to make a point. Exhaust flow is not just math. The best free flowing exhausts are the ones with the least/smoothest bends and the least restrictions that would create turbulence. That muffler looks like it is a 3 inch in 3 inch out. I am guessing Buschur is choking it down to a 2.5 to reduce noise. That is a restriction and the system is not a true 3 inch exhaust.
edit - this is my useless 2c. and do not want to get this off topic. OP good luck with your new exhaust.
Magnaflow hangs lower than Buschur:
compare to Buschur:
Buschur Racing EVO X Crossflow thread
something that I would really take into consideration.
mmartahus
49
Feb 11, 2013 05:34 PM
mmartahus
Oct 29, 2009 11:45 AM
mmartahus
Aug 14, 2009 07:17 AM
mmartahus
10
Dec 22, 2008 03:06 PM
