OFFICIAL: Enkei RPF1 Wheel Thread
#227
Do any of you guys running the 18x10.5 +15 have any rubbing issues in the front on full lock turn im dropped on springs right now,coz ive heard they rub on the liners, thanks for the input I love this rims this is the only issue stopping me to pull the trigger
#228
#229
I think almost everyone who did the 10.5" +15mm have the rubbing at full lock up front.
But like Steven88 said, wait for it to fix itself or you can also do the rubber mallet + heat gun trick to push the liner back if you want.
Heat liner up
Put mallet on the wheel
Have someone slowly turn the wheel to "push" the liner in/away a little bit
If you aren't concerned about rolling the rear fenders (which you will have to), I wouldn't see why this fix would be holding you back?
Heat liner up
#231
how much camber do we need to fit in the 18x10.5 +15 with 275 tires?? Im on swift springs, but i really don't want go more than -2 camber in the rear because the car is just under steering too much...
#232
go 10.5..you will not regret it...i was in the same boat as you before i got my wheels...i'm glad I went 10.5 +15 instead of 9.5 +15
if anything, I feel that the 10.5 +15 aren't aggressive enough...haha I know, I'm crazy...but seriously...the rears stick out just by a little..the fronts is nearly flush...this is my current setup
18x10.5 +15 275/35/R18
rear fenders rolled
swift springs
-2 front and -1 rear
rear fenders rolled
swift springs
#240
http://www.flickr.com/photos/35457279@N06/5064449188/
http://www.flickr.com/photos/35457279@N06/5064448978/
A couple recent ones where the wheels are more or less visible.
