OFFICIAL: Enkei RPF1 Wheel Thread
#466
On 18x9.5 15,mild drop, are you guys having to roll all 4 or just the rear? Using 265/35/18 I really want these wheels but looking to have to pull anything and roll minimal. is it s pipe dream?
#472
All depends on the what tire manufacture you go with.... I have found that Hankook rs3's and v12 evo are made a bit narrow and will look like they have a slight stretch to them.(This will help keep you away from any rubbing issues). Nitto nto1's and toyo r888's for the most part will stick out enough to keep the lip of the rim safe from any "accidents"or road chips.(At the cost of possible rubbing issues). It's really up to your style if you like the stretched look or flush fit. Too much tire stretch renders your car useless when it comes to handling..
#475
i'd do 265 on the 9.5
i have 255's on a 9" rim on my sti, and the fitment is perfect. they are toyo r1r. some tires do run really wide such as the rt615s etc. so a 255 for a certain tire could really be a 265. you just need to find which tire you want to run and read the specs.
this thread makes me want to get rpf1's for my evo. everyone's car looks awesome.
#480
you CAN fit 275/35/R18 on a 9.5 and that wouldn't hurt a thing...tire manufactures actually test 275/35/R18's on a 9.5 frame and they use that as a standard
for 10.5 widths, you should be looking at 295/30/R18's...or something along those lines....but the selection turns to complete **** at that width....and 295 is absolute overkill really...so most people stick with 265 to 275/35/R18 for the 10.5 width, and sacrifice a little by stretching and exposing the rim more
