OFFICIAL: Enkei RPF1 Wheel Thread
#602
Haha. I didn't even notice that until you said something.
I'm still trying to decide if I like RPF1s on the X. Im thinking about ordering some black ones for my WW, but still not sure if that's what I want to go with. Some pictures make them look AWESOME.. and then some pics it's okay.
#603
#604
Basic alignment at tire kindom. Nothing fancy. There is rubbing with these tires on larger bumps in the rear and it has damaged my inner fender in the front part of the fender.
Tire specs were in the post you copied, but I'll put them up again just for you . Nitto NT05 275/35-18.
I am rolling the fenders soon and putting on the 4100s. I will probably not lower it too much more.
#607
Do any of you use spacers with your RFP1's? The reason I ask is that when I had them removed (w/summer tires) and had the OEM with winter tires installed in November, the mechanic stated I should have spacers installed on the Enkei's.
Can you tell me the size if you are using spacers?
#608
#611
*Not a photographer!!!* Nothing special but here are a few P&S pics of my X. I need to get an alignment and adjust the camber. Rear fenders had a minor roll done to them.
Wheel/Tire/Drop Specs
Offset: +15
Color: Matte Black
Tires: Continental Extreme Contact DWS
Tire Size: 265/35/18
Drop: KW Variant 3
Lugnuts: Muteki Neo Chrome joints
__________________
Offset: +15
Color: Matte Black
Drop: KW Variant 3
__________________
#614
Offset: +15
Color: Matte Black
Drop: KW Variant 3
__________________
Offset: +15
Color: Matte Black
Drop: KW Variant 3
__________________
#615
Want these wheels, not diggin the RPF1 center cap option..does anyone know if you can use/fit the slimmer fit center cap option from the GTC01,RP03,PF01, etc...or we stuck with these high center caps as the only option.
Thanks
Thanks
