Oil catch cans installed
Sorry for reviving an old thread but I was looking to install catch cans and wanted to see if anyone else since April has done this? Also, which brands of catch cans are being used...
Thx.
Thx.
The correct way to hook up a catch can is from the pcv to the can, can to intake of turbo.
Under boost it sucks the crank pressure out, goes in to the can where its baffled and the air is separated from the oil..oil stays in can and the air then goes in to the intake.
There are ways to hook it up exactly as you said but still get it wrong. If the catch can is sideways, it's useless. If you take the vent or breather from the crank case and put it to the top of the catch can and then connect the intake side to the lower portion of the catch can, it still works but defeats the purpose of putting the outlet on top and inlet on the side.
There's two black cans, you can see the first one coming from the crank case (vent?) and goes into the black catch can and then into the intake manifold. This is pictures 1 and 2.
The second comes from the crank case (breather?) and goes to the black catch can sitting just to the left of my blacked out alternator terminal cover thing, then goes to the intake just before the turbo, on the underside of the pipe. This is pictures 3 and 4. You can see the tubing going around the back and to the lower nipple and then exits through the top nipple and to the intake.
I purposely put it back there to hide it, a catch can isn't really a "WOW LOOK AT THAT BLING" item to me I almost powder coated my hood rod bronze but someone with more sense than me said no, that's not something to draw attention to... similarly I don't want catch cans to stand out.
Yes, correct, and correct.
The crank case is PCV. You will have greater effect if that can saw reference line to the turbo. IF anything that can needs a reference line as well VS the turbo pulling the vapor out of the head (valve cover). It still works but can be made to work better of course. There is always more than on way to skin a cat for sure.
PS: I don't think it would work very well connecting both the crank case breather and crank case vent to the constant vacuum at the turbo inlet...
I'll draw a diagram this weekend. Your way is a good way and functional, but there is a better way. Not bashing you by no means, Its clean and works just showing there are other ways.
