Freshly powder coated Primo intake and Boomba fuel rail
Liquid Powder Coating did the powder coating. They do a great job. I forget the color names.
Boomba Fuel rail powder coated purple
Primo 3.5" intake powder coated Ferrari Yellow or something. It has a lot of flakes in the color. Looks great.
FIC 1100cc injectors
The white box next to the intake is a Perrin EBC.
Nice color selection, but I can't believe what your powder coater did with the fuel rail.... It doesn't even look like the FPR mounting hole threads nor FPR port itself were plugged while it was sprayed, the pressure port was literally just coated over, and the o-ring sealing surface of the feed fitting (the L-shaped pipe) wasn't masked off either. Wow, and it looks like they might have just straight up coated the entire feed pipe while it was bolted to the rail. I also see runs on the nearest mounting tab of the fuel rail.
No personal insult intended, but you need a new powder coater.
RavSpec
Sep 11, 2015 11:44 AM
Dannievo
Jul 23, 2013 02:50 PM
