Front lips that fit w/ SSP Aluminum Undertray?
Does anyone know what front lips will fit the X with the SSP Aluminum Undertray? I have one installed and im dying to install either an OEM front lip or the Blacktop Aero Varis replica. but it wouldn't hurt to know what other options I have
I would agree that you should be fine.
That said, the ssp undertray did not fit with my varis/runduce front bumper. Given that's an aftermarket bumper and lip combination so not the same thing, but point being you can run into problems. The bumper/lip setup comes with all the same holes for mounting the stock undertray, and is supposed to be completely compatible with the stock undertray, but the SSP tray is I think a bit wider/longer then the stock pieces. As such it would not fit and I had to take it into a shop and have them cut ~1/3" off all the way around the outside of the lip.
So even if it doesn't fit the lip you get, it can be modified to fit it
Ya I have the original one piece ssp tray and even on the stock lip and bumper on the driver side by the wheel it was about a 1/2" too long but bolted up and fit just fine. Apparently the new 2 piece design is spot on though so either way though its definitely worth it! I love my ssp tray saved my *** a few times lol
Blitz
Mar 2, 2010 10:27 PM
