help on transfercase evox mixing oil fluid sp3 with gear oil
does anyone know if that is any seal between sp3 oil and gear oil .... my evo keeping asking more oil ... more oil and now is complete full with both oil ...
my tank on the rear ( sp3 oil is always low)
and i know they are mixing because i drain the gear oil and is mix with sp3 oil
The oils should be separate. There are two separate drain and fill plugs and when you look at the housing on the outside you can see where the two chambers probably exist (based on molding in the housing).
If your fluids are mixing, that is probably not good.
Source: I just replaced both of my fluids this weekend and both were separate when I drained (I drained both first then filled).
