Speed Bleeders for Evo X
After replacing the stock lines with Goodridge SS lines from AMS I was thinking it sure would have been easier bleeding the brakes with Speed Bleeders in each caliper.
I spotted this thread in the Evo 1-9 forums:
https://www.evolutionm.net/forums/sh...=speed+bleeder
Can anyone confirm these part numbers also working on the Evo X? I'll check the Help section at Pep Boys later today and update what I find.
The clutch slave uses a longer one than the brake calipers, need 2 for each front caliper, 2 for each rear caliper so 8 Total for the Brakes and 1 for the Clutch Slave.
Brake bleeder spec: 10mm x 1.0 x 33mm (31mm will work also)
Pepboys #12706 $9.89/pair
NAPA #675-1570 $11.69/pair
Kragens #12706 $11.xx/pair
Speedbleeder #1010S $14.xx/pair
Clutch bleeder spec: 10mm x 1.0 x 35mm
Clutch Slave speed bleeder
Pepboys #12709 $9.89/pair
NAPA #675-1573 $11.xx/pair
Speedbleeder #1010 $14.xx/pair
Also I'm unsure of how much of a difference bleeding them with the engine on at idle would be compared to the car being off. At the time it was late at night and I didn't want to **** off the neighbors.
I found some at Pep boys but they only had 2 packages. Instead of driving all over the city I bought the rest at http://speedbleeder.zoovy.com/ where they were $7 each. BTW there is an Inner and Outer bleeder on both the front and rear Brembo brakes on our cars so you need 8 total.
Would still be nice if someone chimed in if running the car at idle while bleeding made a difference.
Also if someone has the proper order to bleed the brakes that would be nice to have all in one spot for reference too.
Thanks!
Thanks!
Under the stock airbox area on the front edge of the Transmission you will see the Clutch Slave Bleeder. It's part of the hydraulic clutch system that controls how fast the clutch can be engaged and released, often people remove the restricter or replace that section with a braided SS line to allow quicker action. Basically if you need to bleed the clutch due to air in the system, fluid contamination, or as part of a clutch replacement, the bleeder works similar to brakes where you normally have to pump the clutch pedal and have a friend open and close the valve to avoid letting air back in during the pumps. Of course you still need to top off the reservoir but it makes it a ton easier.
Some pictures of what a typical clutch slave looks like:
https://www.evolutionm.net/forums/sh...d.php?t=128340
pcguru2000
Aug 7, 2017 03:29 PM
tom@kartboy
43
Jan 5, 2017 04:57 PM
rob_d
27
May 2, 2016 09:23 PM
pocoRA
Mar 17, 2005 08:19 PM
