Wonder if this is going to fit when on the ground?
I don't have lugnuts yet, so I couldn't put the car down...
18x10.5 +15 RPF-1 (19 pounds!)
285/30/18 Hoosier A6
Rear fenders rolled and pulled lightly, -2* camber
Front fenders pulled lightly (not much to roll), -3* camber
Pictures are at full droop on the lift.
And clearance inside (on the lift, so this will decrease)
Touge Factory has these same wheels on street tires fitting... so I think they'll be OK.
I am planning on raising the front though. There's not enough room for larger bumps on my street tires, these will hit the fender liners or fenders for sure.
-2 and -3? A rep from a local tuner informed me that when I put on the same wheels with the same offset at stock height, that I'd not need to roll or pull anything, nor would I have to adjust stock camber. I'll be running 275/35's though.
