work cr kai's 18X9.5 20MM
Im lowered on the .9" work springs and have just ordered a set of these rims. will I have rubbing issues if i am running a set of 255/40 R18 tires of them? thanks all
got the rims on stock tires for now. No rubbing issues what so ever lock to lock. May need spacers though. I asked the installer if it would be possible to put 265's on and he did not think so.
I would not recommend running a 255/40/18 tire. This tire size is larger than your stock rolling diameter and will most likely rub your fender liner on full lock turns. 245/40/18 stock tires do work however a 265/35/18 would be an ideal choice if you are getting new tires.
Stock 245/40/18 tires do work on 18x9.5 wheels, you can run as small as a 235/40/18 (very stretched) on this wheel size. It is recommended to go wider though for the best fitment on the wheel and overall match to your stock rolling diameter (or close to).
-Dan
-Dan
With stock tires and 18 x 9.5 +20...will I still need a camber adjustment? Also...I am on Eibach springs.
Thanks for the help!
