Need more rear toe adjustment?
Anyone have any ideas on how to get more rear toe adjustment on an Evo VIII? I have only seen one vendor who sells adjustable links (Nagisa Auto Pillow Adjustable Toe Control Rod) for the rear toe and they are rather expensive.
My car is plagued by a LR that can barely get within alighnment spec. I have lots of room for adjustment on the RR, but can't say the same for the other side. Basically, to get near zero toe the max negative camber I can run is something like .4 if I want both sides to be equal do to the limitations of the toe setting on the LR. The toe bar is maxxed out at full extension.
I got the rear toe adjusted with KW Robispec setup
You need a rear sway bar linkage that's adjustable.
check out this thread:
https://www.evolutionm.net/forums/sh...d.php?t=326523
goofygrin
88
Jul 24, 2022 08:22 PM
asu11
Jul 25, 2015 07:55 AM
2008, adjust, adjuster, adjusters, adjustment, ebo, evo, evolutionm, r32, rear, tire, toe, volkswagen
