JIC Coilovers - 3 models for the X!
Hello everyone!
JIC has the new suspension on the way and we are getting the exclusive on them to get you the best price out there!
Here are the models 3 models.
JIC FLT-TAR Race Coilovers Mitsubishi EVO X CZ4A 08+
The JIC FLT-TAR is the flagship coilover system. All FLT-TAR coilovers are designed on US-spec vehicles for US streets, fitment and performance is unmatched. Included in the kits are pillow ball upper mounts with adjustable camber plates. For flexibility, the dampers have 15-way compression and rebound adjustability. The spring rates are of the linear-rate type with independent ride height adjustable lower brackets. This allows adjustment without compromising damper compression or rebound travel. Based off of racing technology, the FLT-TAR is a street performance suspension, customizable for full time track use. NOTE: some applications may come with a rubber bushing upper mount. A Pillow Ball upper mount may be substituted for additional cost and with no warranty.
Hard Setup Race Coilovers
Model: CZ4AFLTA2H List: $2,189.99
JIC FLT-TAR Street Coilovers Mitsubishi EVO X CZ4A 08+
Model: CZ4AFLTA2 List: $2,097.99
JIC FLT-TAS Coilovers Mitsubishi EVO X CZ4A 08+
The JIC FLT-FAS is a coilover suspension set up ideal for the enthusiast that will use the suspension on a daily basis and occasionally for the track. FLT-FAS features a 10 way adjustable damper. For strength, strut-type suspensions feature a wide shaft while multi-link type suspensions feature the smaller shaft damper. FLT-FAS include front pillow ball upper mounts and front adjustable camber plates. Also included are springs of the linear-type for laser precision handling and adjustable lower brackets for ride height adjustments that do not affect damper travel.
ADJUSTABLE DAMPENING:
Available for all applications with 10 ways adjustability. With this feature, you are able to tune your suspension dampening up to your spec.
ADJUSTABLE PILLOW BALL UPPERMOUNT:
Included for all vehicles for the front and some for rear application. Adjustable camber plate also included for most vehicle front applications with Macpherson Strut suspension systems.
COOL BEND LINEAR SPRING:
Linear rate spring manufactured using chrome silicon metal alloy with cool bend process.
HIGH TECH TWIN TUBE DAMPER:
The twin tube dampers show the different sized shafts. because strut-type suspension require more strength for support, the wider shaft (right) is the damper of choice while the narrower shaft (left) is for multi-link / double wishbone suspension.
DUST BOOT COVER:
Durable protective dust boot cover protects the damper shaft from dirt and debris.
HEIGHT ADJUSTABLE LOWER BRACKET:
Adjustable height aluminum CNC machine-built bracket for double wishbone or multilink suspension.
Model: C4ZAFLTA1 List: $1,567.99
http://www.vividracing.com/catalog/s...1&filter_id=14
If you like to purchase and check EVOM special pricing you can PM for me
Regards
Jon
DUST BOOT COVER:
Regards
Jon
FS[Pacific NW]: JIC Magic FLT-TAR Coilovers
GSXRiderK6
Dec 30, 2015 11:00 AM
THmotorsports
EvoX 'For Sale' Suspension / Brakes / Handling
689
Jan 22, 2014 08:24 AM
brenner
Dec 21, 2012 02:48 PM
