Offset Discussion:
has any one seen these wheels on a x this size and offset i have been lokking for picks and cant find any there are shon on the static x web site man they have to look way wide
I have a set of RE30 in 18x10.5 +25. Putting aside for the moment the fact that your wheel is a 19 I think one problem will be the backspacing. Ive heard the 18x10+35 works. If this is true then the 11' wide +25 being only 2mm or so more rim on the inside should work as well. It will rub the fender liner in front, and worst case scenario you gotta run a tiny spacer to help with strut clearance, which had better be aftermarket by the way. On the fender side its going to be like running a 10.5 +19. With that you must roll the rears and run a stretched tire with around -2 camber with a decent spring rate I would say just to be safe. I dont have any experience with 19's, and I actually havent even mounted my 18's yet either, so this is just guesswork.
