Suspension/Coilover Noise? Rattle?
I installed my BC coilovers roughly a month ago, and I am just noticing some almost rattling noise. The noise only occurs when driving not on a smooth surface, as soon as its bumpy you can hear it. You can mostly hear in the rear, it almost sounds like it is in the trunk. At first I thought it was the top mounts, but they are nice and tight, and I rechecked everything and everything is on there. The only thing I could thing of its the actual spring moving, but that wouldn't happen would it?
Any help is appreciated!
- Chris
- Chris
I had same noise form the start. Try getting some rubber between the car and the coilover. Basically making a gasket for it to rest against. See if that helps, I am curious to know if that solves it. That will tell you if the noise is related to the top mount or not.
