TPMS cost $90 per piece!!!
#31
I work in a dealership as a tech assistant so let me clear this up for you all. New TPMS sensors or TPMS sensors that have been moved away from the vehicle for either extended periods of time or an extended distance from the vehicle will need to be "registered". Dealerships have a special scan tool called the "TPMS Scan Tool" that we plug into the DLC (Data Link Connector/ OBDII Connector) that tells us the temperature, pressure, location, speed, etc. of each wheel. If these sensors read 0's across the board or are misreading such as it says "10psi" when we know it has well over 20 psi than we have to register all sensors. This process only takes less than 5 minutes but the dealership will obviously make all the money they can off you.
#32
So as someone looking at aftermarket wheels and probably a summer / winter wheel/tire swap once a year can I conclude that the options are to:
A) buy second set of tpms sensors and have each set of wheels "registered" 2X a year
B) buy some sort of adapter to move the original sensors between wheels which would seem to negate the need to re-register but might be a real pain
C) Live with the serivce light on the screen (not very desirable really)
Now if one were just getting aftermarket wheels but didnt need to swap summer / winter then I assume moving the original TPMS or buying a second set from Mitsubishi would require a one time set-up.
Since a lot of people seem to have aftermarket rims I'm curious what people are doing in practice for this problem.
#33
#34
Here is the story...
I swap sensors for our customers at my work during season changes. They want the blingy rims for their MB's, or BMW's and DO NOT want the dreaded TPMS light on in their car. I have NEVER had an issue mounting a TPMS sensor in an aftermarket rim/tire combo since I have been working here.
We had a customer with a S600 and his sensors WOULD NOT fit due to the design of the wheel. With permission from the customer, I Gorilla glued the sensor(minus the stem) to the inside of the wheel. He never had an issue.
They always need to be recalibrated though. Our tool to recalibrate the sensors is made by Bartec. I believe it's the Bartec 400 Plus IIRC.
#35
all you need to do to calibrate them is get a circular magnet with a hole thru the middle of it. Then place that magnet on the valve stem for about 10-30 seconds (time varies) and repeat for each wheel. I dont believe you need the scan tool to do it.
#36
That is the case with the early model TPMS sensors. An example would be the early model Vettes. You need a magnet in conjuction with the reset tool. i'll take home the one we have here at work and take pics when I get home. A magnet is included with this kit.
#37
Tire Rack has the same 35 megahertz tps sensors that will work for the Evo X for $210.00. Afterwards you have to go to the dealer and they will charge $75.00 to calibrate it. So you're looking at $285.00. Hope that helps!
#43
I've had lousy luck with the tire shops around here. They all seem to have circa 2006 TPMA machines which can reset the individual sensors but not the central unit, which means they can't put the central unit into learn mode, to find the new sensors. I've just been living with the light, which I will fix eventually. Unfortunately, none of the cheap tools can reset, I'd pay $400 - $500 for the tool and then charge people $25 to reset, but I can't even find them that cheap! the good ones that I know can fix this seem to be in the $1500 range, which would take a long time to recoup, even at $75 a shot.
