are these offset too agressive for evo X
i am selling these (NOT on this forum) i am an active member on my350, the offset is for the z, i am just curious how it would look on a evo X.
19x9F +15
19x10R +20
thanks
19x9F +15
19x10R +20
thanks
1 Post
Look sick, but destroy the center diff. Thats a rear wheel set up not an all wheel setup. You cant tires to equal the same overall circumference between front and rear. I know, Ive tried when I was almost given rims. I got close but not close enough.
1 Post
I was told opposite. When using, lets say a 245/40/17, and mount it to a 9" wide wheel it will not be the same rolling circumference as a 245/40/17 mounted on a 10" rim. The 245 would be stretched compared to the 9" wheel, thus reducing the rolling circumference making the front and rear tires diff sizes. Isnt this why if you buy one tire to replace a flat, it should be shaved down? Anyone know the tolerances? 1% 5% diff ok?
but isnt it why guys, whom run staggered fitments will have different aspect ratio? for my front 9'' , is mounted 235/35/19 and 265/30/19 for my 10' rear.
1 Post
^^^ Your posts are usless and uniformative. My post is trying to get an answer. What next, you gonna post in the "For sale" thread and say you dont have anything for sale yet? Then go to the "ecuflash" thread and say you dont own a tactrix cable or a computer? Im adding to this thread, you're stating that you don't know the answer. Useful ... not.
Now to the OP ...
235-35-19
Circumference: 80.01 in 2032.2 mm
265-30-19
Circumference: 79.32 in 2014.7 mm
Very close, but not the same size. That is why I am curious to see the tolerances in the evo's awd system. If it has to be within 10mm these would destroy the center diff, but if it has to be within 30mm the tire combo should work.
Now to the OP ...
235-35-19
265-30-19
If a new tire with 3 old tires will jack up the transfer case (as we've seen attributed on the 8/9 TC), then I'm thinking that even a 10mm difference is likely unacceptable.
Personally I would let the Z's and G35's run the staggered setups... since wheels like in the OP are mostly for show anyway... (flame on?)
Now to the OP ...
235-35-19
265-30-19
Now to the OP ...
235-35-19
265-30-19
aznguru
Jun 24, 2009 10:40 AM
V1RGINEVO9
50
May 4, 2009 03:39 PM
mcwop23
146
Apr 28, 2008 12:28 PM
