Stock Tire and Rim Questions...
So im thinking about getting some rims and would like to use the stock tires and have some questions...with the rims, whats the max width i can do without over stretching the tires? the rims in particular are 8x8.5front and 18x9.5 with a 35 offset, would that work?
wider tires/wheels in back, like on a G35 or 350z look great, but if you have an AWD car *like an evo* then the difference in diameter, even small, will cause vibrations and then cause the transfer case to break.
Stick with 4 wheels and tires that are exactly the same. In fact, you should even replace all 4 tires at one time since 1 or 2 worn tires will do the same as staggered fitment.
If you stretch a tyre over a wider rim, then the diameter becomes smaller to compensate. Having a different diameter on the front and back means the wheels are turning at different speeds, which will cause big problems.
EClark11GTS
Feb 6, 2016 02:26 PM
joshevo22
For Sale - Wheels / Tires
Apr 6, 2012 07:19 AM
DepoRacing
13
Jan 22, 2010 11:39 AM
RED DEMON
Jan 30, 2006 09:50 AM
bigmac
Nov 24, 2004 03:14 PM
