Will fit 235/50R18 winter tire to EVO X?
Get yourself some stock sized 245-40 18s on the factory rim. There are plenty of decent winter rated tires, and some decent All Seasons, available in that size. (go to tirerack, have good selection in factory size).
If you're worried that the widest stance won't cut through Chi-town snows cause they'll be too high, you're worrying about deep deep snow, deeper than your air damn will like and you'll be plowing. For anything 4 inches or less, the width won't kill, and will actually help in ice. For anything more than 4 inches of snow, I recommend the L or your 4x4 F250 you can pick up cheap if you don't already have it.
an Evo which is a AWD "rallye car" and the most fun you can have whith those car are on dirt road and icy road.
If you want the fun go narrower and with the best winter tires you can find.
^ They're too tall - won't fit (well, they will, but your going to rub the hell out of everything).
Also, 17" wheels will not clear the front rotors, therefore 17" wheels will not fit
just to clarify, I don't care about 17s... wanting to run a 235/50/18 LM25 on my stock GSR rims.
An extra 1.5" might be a bit too tall.. I am going to be running 275/35/19s for summer and they are 1" taller and they will work but it will be tight and will rub slightly when you turn all the way. Granted you are only going to be turning this much at parking lot speeds but the evo has a horrible turning radius any way so the more you rub the less you can turn. I would say 1" taller is the most you can go just from taking a quick look at my car the other day
I have the Avid W4S tires. I call them snow tires. I also call them scary. The OEM and the Z1's spoil me. The snow tires make me feel like I'm lifting off the road. They're cheap, they have decent traction, they have great tire wear. But I wouldn't buy another set. I hear the Continentals are worth looking at... no worry here, I have one or two more winters on these scary tires. Just gotta get to the track one more day :-)
I had the Michelin X ice on a G35 and feel those tires were outstanding.
I bought The X ice 2 for the EVO believe it or not but it does handle as good and brake as good as the Infiniti. I am happy but I don't feel the handling is as good. No prob lem with traction, lateral handling is far to be as good and braking is also not as good.
I did not test them on the same car so it is difficult to judge. The EVO is stiffer so it can make the difference.
I am not talking about normal driving but going to the limit. (ice racing)
For every day they will be perfect. Whith those tire you will enjoy the EVO on the snow but be carrefull it could be tricky to stop.
yup - tire rack - i got dunlop 235/40/zr18's the 3d's for my evo x and there great , ive had the car buried up to the axle in mud and theyll pull you right out f'd up the body kit ,but they have claw like grip. In the snow they cut through really good and on ice they grip awesome, a fr-wd vw got stuck on ice patch in my drive they had snow tires to i think firestones? Had to push them out. The dunlops felt like they had studs not a problem on ice. Ive had the dunlop m3 also on my ms3. Dunlop tires kick *** and the drop of size hasnt really affected performance, in heavy downfall i can still do 60 on backroads and they feel confident to keep going. I live in nj we just had a blizzard and three more snowstorms after that.
