View Poll Results: Which wheels look better on the evo x?
ENKEI RPF1
81
43.55%
ENKEI NT03-M
85
45.70%
NEITHER
20
10.75%
Voters: 186. You may not vote on this poll
RPF1 or NTO3-M?
RPF1 or NTO3-M?
So far I've narrowed down my wheel choices to these two, but now Im stuck. I owned a set of rpf1's on my old acura rsx-s so I know those are great wheels, but I think evox's look better with more spokes. Well let me know what you guys think.
the rpf is the obvious choice for its performance.but its kind of overdone.the nt03 is the better looking wheel but would be a pain to keep clean.i wouldnt run either but if i had to choose between the two i would run the nt03s.
I just looked at the wheel weights at Tirerack. As they didn't have 18" NT03-Ms listed, we'll have to settle to comparing 17x8s. It doesn't matter much, as the weight is prorated per size:
RP-F1 - 15.5lbs
NT03-M - 17.9lbs
That's a difference of just about 2.5lbs per corner! It isn't trivial.
BTW, RP-F1s in 18x8.5 weigh 17.9lbs, same as the NT03-M in a significantly smaller size (ie. 17x8). Just a FYI, if you care about weight.
RP-F1 - 15.5lbs
NT03-M - 17.9lbs
RP-F1 - 15.5lbs
NT03-M - 17.9lbs
Anyone know of a 18x10.5 other than the Volk and NT03M? NT03M is a week or two from being "in country" I'm told. To answer the question, I like both, but the NT03 is the only one with a close enough offset to work in the 10"+ width.
http://www.wheeldude.com/catalog/pro...oducts_id=5713
But they are "rotas" so you'll have to get over that stigma. and they are x10, not x10.5... if that matters a lot. They will weigh a ton more than the cast wheels in question (like 3-4# likely)
