<> Rim Spec <>
<> Rim Spec <>
I was wondering if a rim with specs like 18x10.5 114.3 Bolt Pattern would be bad for performance ?
Depends on the weight of the wheel and tire.
If they are heavier than stock (likely) they will make the car slower in a straight line (more rotating mass to get moving). However, if the tires are good you should be able to corner better.
Wheels that wide might require some fender work.
