Getting CE28N, would 19x10.5 +22 fit without spacer or fender roll?
As title stated, my MR is currently at stock height (may consider -0.9 drop with Work springs)
Would these wheels fit without spacer (to clear the brakes), and have enough clearance for the shocks and wouldn't rub the fender?
What is the maximum tire size width I could go without rubbing issues?
Thanks!
Thanks!
I would say for 10.5 +22 19" wheels:
1- Camber plates
2- 275/35/19 100% no rubbing
, 285/30/19 Tires some rubbing
3- 5mm spacers up front (to clear strut)
4- Massive fender roll, with some pulling
5- Studs
1- Camber plates
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
![Wink](https://www.evolutionm.net/forums/images/smilies/wink.gif)
5- Studs
At stock ride height you'll have zero issues. If you want to lower it though you will need to make some fender mods.
At stock height I was running 19x10.5 +22 with 275/30/19 with zero rubbing.
I don't mean to hijack this thread, but it seems the OP's question was answered and I don't want to create a new thread for a similar question...
I'm considering CE28Ns in 18x9.5 +22 on 265/35. I plan to lower on Eibach or Works springs. Is it safe to say I will be able to fit these with no rolling or spacers? Thanks.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
No spacers needed because CE28N 19x10.5 +22 have enough caliper clearance to clear the stock brownbo brakes.
You definitely will need to roll the rear fenders if you want to use larger sized tires to prevent rubbing.
If you are going for the aggressive fitment look, rolling fenders shouldn't be a factor to shy away. JUST DO IT! It will be worth it!!
