18x9.5 +38 vs +15 Enkei RPF1
Hey guys,
I am trying to figure out if I need to order the 18x9.5+15 or the 18x9.5+38 to get it to fit on the Evolution X.
I saw in one thread someone running the +15 offset, but they said they needed to run near max camber to get them to work.
Would I have problems running the +38 offset?
Thanks!
-Chris
Thanks!
-Chris
so they don't have +20 or 22? not sure about +38 but +15 need to roll fender for sure if u got lowered suspension . if both need work then go for +15 at least looks much better
I run 18x9.5+22 as do a lot of other people ... and if I could do it again ... I'd definitely go more aggressive offset. +22 with a 265/35/18 looks sunken at some angles and perfect at others.
You should definitely go with the +15 offset.
with a little help from camber plates... you can easily squeeze in 275's or larger.
We're running 18x10.5 +15 with Z1 Star Specs - 265/35/18
Rear fenders are rolled...that's it. no other fender mods.
![](http://www.tougefactory.com/evox/evilx1.jpg)
Couple more pictures here...
https://www.evolutionm.net/forums/ev...ng-shot-4.html
Camber plate question...
Thanks in advance.
