Question: lowering springs
I'm looking to get some Swift Sport springs. I know an alignment is necessary after lowering the vehicle but is there anything else that needs to be adjusted such as camber? The drop on these springs is 1.0" front and 0.6" rear.
I would further argue that installing any lowering spring will degrade performance of the X, not improve it at all. I find a lot of people who actually have springs installed all claim that it feels better and there is less body roll. Well this may be how you feel but in actuality less body roll isn't always a good thing. Your perception that the car feels more planted is just that, a perception based on motion. The fact that it "feels better" will only inspire false confidence that the car handles well.
You need to have a lot of extra grip and suspension mods to compensate for the increased stiffness and shortened suspension travel. Just installing springs alone without matching shocks will hurt your damping, give you more bump steer and gimp your well-engineered stock suspension.
+1 looks only.
^If you use the car for DD/track days you should stay with the stock suspension. Only pro race drivers can push the X to it's suspension limit in stock form, you're better off going to a driving school if you want better handling.
But if you want looks only and drive on the street it's not really going to kill your handling either. Only on the track you will notice the worse handling when driven hard. It will wear out your shocks faster too.
Mild drop to maintain a decent amount of travel, solid bump in spring rates designed to work with the standard valving, and rates that are designed to work wtih the EVO suspension geometry is key.
Honestly, the bigger the drop, the higher the chance that it's a "style" spring.
SO my opinion is that it depends on the springs. We'd like to make some for the X.
Yes you'll get better performance from a good coilover, but IMO some coilovers are hardly upgrades.
- Andrew
WTB[Northeast]: Lowering Springs
Spartan716
May 13, 2016 05:53 AM
