MR Bilstein vs GSR KYB
If you plan to get new struts, get the full coilovers, so the strut is matched for the springs. They will last longer. If you just want to lower it get lowering springs but your struts wont last very long.
IMO if you do any coil/strut mods, get full coilovers they will last longer and you wont regret the purchase later on. No point in going half way and getting lowering springs. Its way better when you get matching coil and strut. You dont need the 3 way adjustables if you dont track your car.
Plus, you can get a set of MR Bilsteins and get them revalved to your specifications, pick your spring rates, and end up with a better handling car on more reliable struts than the majority of these full coilover setups at a substantially cheaper price.
Frankly, if you don't track your car, you don't really have any reason to be modifying your suspension at all.
I dont think you guys get the question. I'm asking about the difference between the Stock GSR struts (KYB..I think) vs the stock MR struts (Bilsteins). Lets not get into coil overs. I plan on getting Swift springs and would like to know if its worth it to buy stock MR Bilstein struts or to just stick my with stock gsr struts...
and who is Mr.OT man? lol
and to counter whoever that said coilovers are the way to go - ksports are the worst coilovers you can get, and they are not matched. it's impossible with their way of reusing shocks/valves/housing. just goes to show it's all in the r&d.
i was in this dilemma as soon as the MR came out and saw the bilsteins. there were a few that were sold here that i thought were priced pretty good but i still didnt pull the trigger on them.
i have come to the conclusion that since the car is a DD and with brand new struts there was no point in getting the bilsteins, maybe 3 or 4 years down the road once i have fully utilized the kyb struts. so for now i am just wanting to get swifts springs to lower the stance. so while the bilsteins might be superior than the kyb, for now the kyb will do its job and do it well.
in a nutshell just like with any other mods, you have to ask yourself what is the purpose of this mod and take it from there.
Well I'm not sure what you're trying to do but changing out the springs will stiffen the ride some. I have the Swifts and it is noticeably stiffer. I don't think it's bad at all but that's me. I feel the bumps more and it does have less body roll. It's a nice compromise.
If you're unhappy with the way the car rides right now, then I don't think Bilsteins are the answer - you need a different car. If you're ok with it, then the KYBs will be fine.
Except most coilovers are made with struts pulled off the shelf often with arbitrary spring rates from other applications. The idea that full coilovers are somehow magically mated to each other from the factory is just magazine marketing.
What's the point of modding at all if it's only used on the track.
With that logic anybody who doesn't use their car on the track should be driving a 10 year old beater car. Afterall who needs an even a stock evo's performance on the street. It doesn't matter if you track your car or not....what matters is you make your pride and joy evo into what you desire, whether that's the show route, or the performance route, or just plain stock, do what brings you happiness with your car. I really like the look of a lowered evo, and by the way if I didn't like the look of an evo in the first place I would not have bought one...so if you think lowering it makes it look even better..do it, it doesn't matter if you track it or not. For those who track your car, you do it because that's what brings you happiness, respect and allow others to do what brings them happiness. Everyone has to do what's right for them, not what what you think is right for them.
Ok I'll get off my soap box now.
There are a few threads on this--but the ride on the bilsteins with the swift spring is 10,000 times better then the kyb set up.. swift springs if I am not mistaken are maybe 10% stiffer then stock--the ride is much smoother and not so choppy..Makes my DD a real pleasure to drive now. As for modding the suspension only if you track your car...well, no. If you want to add some stability --add a rear bar as well, that will add the spring rates and firm the ride a little more and take some of the roll out of the chassis in turns...also another nice adder..Then, maybe some bushings.. I have them all and they work great without degrading the ride.
